fuel pressure regulator HELP!!!! - FirebirdV6.com/CamaroV6.com Message Board
  • fuel pressure regulator HELP!!!!
    I know this has been posted before but im new at this and my car is having all the symptoms of a bad regulator. Car hard to start and doesnt hold pressure like it should i was wondering where is the regulator at on a 99 firebird....and can anyone tell me exactly how to take it off or should i pay the dealer 200 dollars to do it.:mad:
    Re: fuel pressure regulator HELP!!!!
    look at your fuel rail. drivers side. its the round pc build onto the rail. approx 2in in dia.
    easy diy (do it yourself)
      you are gonna need a special J tool to get it out of there as well.
        Do you mean the pressure is not correct with the engine (and fuel pump) running?
        or do you mean the pressure will not hold when the fuel pump is not running?
        If the fuel pump is not running, it is normal to see the fuel pressure drop to zero. (there is no accumulator in the system to hold pressure when pump is stopped)
          well im not totally sure i just no it takes i long crank to get my car to start but if i give it alittle gas it starts up faster.it seems like the line is holding its pressure when i start the car but when its started its totally fine.
            Check out this thread: http://forum.camarov6.com/showthread.php?t=6976
