The oil fill neck that is attached to the valve cover is loose. Can this piece be replaced or do I have to buy a whole new valve cover?
Oil Filler Neck
Re: Oil Filler Neck
I'm pretty sure you can buy just that but it will come with the cap making it more expensive than it should be. :\
Re: Oil Filler Neck
Remove the neck and just use the cap, is what i did.<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.
Re: Oil Filler Neck
twist, pull right out
The trans oil is hard to get in/out methinks2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
Re: Oil Filler Neck
My filler neck was loose as well, and the more I tried to remove it the more loose it became. Finally gave up trying to remove it cause it looked like it was going to break off. Really didn't want that, and cetainly didn't want to leave it loose. If left loose the PCV system will draw air through there and with the air comes dust and dirt which collects in the rocker box area of the heads. I had to do the valve cover gaskets on a 86' 3.8 that had a loose oil filler cap and I couldn't believe the sludge and crap that had collected under the valve covers. The rocker arms where half covered!! Took alot of work to clean it all out. (Car had 245 K miles on it!)
So to make a long story short, for my FB I forced Red RTV into the gap between the base of the filler neck and the valve cover. This not only secured the filler neck, it also sealed it up.Now Playing: \'99 Pewter Firebird, stock, bone stock, and nothing but stock, so help me God!<br />Comming attractions: K&N Filter, Lid Mod, Intake Bellows Smooth Pipe Mod.<br />I dream about: Forced Induction (TC or SC) or NOX (or both!)
Re: Oil Filler Neck
You have to kinda play with, and pull VERY hard. It will come out with out breaking.<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...5 days ago
