smell antifreeze when I use heater - FirebirdV6.com/CamaroV6.com Message Board
  • #16
    I just started smelling this Saturday....I think I think I mightbe having this same problem with my 94. (but then it just turned 175k yesterday)
    The only thing is when I started to smell it I noticed a little smoke coming from the vents
    <a href=\"http://whitebird94.ls1fun.com\" target=\"_blank\">http://whitebird94.ls1fun.com</a>
    • #17
      Smoke comin' out of the vents is most definitely a heater core problem.
      1992 Arctic White Firebird<br />3.1L V6, TB Coolant Bypass, CAI, Turbo Muffler, other little things.<br /><br /> <a href=\"http://www.geocities.com/colinobu/MyHomepage.html\" target=\"_blank\">http://www.geocities.com/colinobu/MyHomepage.html</a> <br /><br />\". . .Finger in the air and the flag still wavin\'. . .\"
      • #18
        Re: smell antifreeze when I use heater
        I can smell it too when my heater is on but I don't have any leaks or puddles forming . Any thoughts ?
        • #19
          Other than reviving a 6 year old thread... You probably have a small heater core leak. I would change it yourself if you can do it yourself. If your put it off keep an eye out of antifreeze on the passenger side floormats (heater core is right behind the glovebox).
          Doug<br />1996 Camaro RS M5 Y87<br />SLP Bilstein shocks, Eibach springs, 1LE frt/rear sway bars
          • #20
            well my car is now over heating and it gets hot really fast
            In the last 9 months I have replaced the thermostat the radiator cap and flushed and rodded my radiator any one know why its over heating now , it over heats so bad that the engine has a hard time staying on
            • #21
              And my heater doesn't work and my coolant was brown and the mechanic said I had alot of rust. And I noticed that when it over heats one of the hoses shakes and pulsates
              • #22
                Problem Fixed. It was my water pump it went out . The fan inside the water pump SPLIT in HALF. I thought it was the thermostat so i put it in boiling hot water and if opened and I had just got my radiator flushed and rodded so through process of elimination i figured it was my water pump..
