Does it matter where the motor ground strap is? - FirebirdV6.com/CamaroV6.com Message Board
  • Does it matter where the motor ground strap is?
    Gm has it at the rear of the head and to the firewall, i have it on the left side of the block and to the passenger fenderwell, will this work ok here?
    Longtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,
    That still should be ok. Just make sure your connections are free of paint so it gets good contact
    Ron
    I know - Camaro 67-02.. 2000 Camaro V6/A4 Black T-Tops<br />1969 Camaro 350/PG 12.69 @ 102.5 1966 Chevy II Wagon 283/PG Destined for NHRA stock eliminator.
      2 days ago
    • Doodler
      97 Camaro base with expensive sounding noises
      by Doodler
      Still trying to find oil leak
