Y-pipe bolts screwed - FirebirdV6.com/CamaroV6.com Message Board
  • Y-pipe bolts screwed
    I been having exhaust leaks, so my wideband sensor isnt being accurate.
    I was trying to put the y-pipe back on right because I thought it was kinda overlapping with the header on one side. On my passenger side header I could only get one of the bolts half way through the other would go all the way in. I used a electrical impact gun and it still wouldnt go further in. I tried it on the one that went all the way in fine and it broke the bolt off.
    So now I have to drill it out.
    Anyone know where I can find a new y-pipe bolt?
    thanks
    Re: Y-pipe bolts screwed
    p.s. I got a new oil psi sensor and my oil pressure is reading like 60-70psi!
    I think it went from 30 -> 65 because I fixed my rear main leak.
      Did you ever find the bolts, I need them also. Just got an exhaust leak also.
        i think my friend is gonna send an old rusty one
        i'm sure you can get one from the stealership
          take a botl to lowes or home depto and get a one in the same length
          just make sure it is grade 8 will cost like $5 for 4 bolts and nuts/washers
          www.turbov6camaro.com
          1997 3800 Series II Camaro
            which would you prefer:
            to go to the dealership? $3.50 for 1
            or go to a hardware store?
              Great to hear your oil woes are solved!
              Man, that must have been one h.e.l.l. of a leak to affect pressure like that. Your sure it wasn't the new sender?
                store
                  Theres no way to tell with these dummy "gages" :(
