What is up with my RPM gauge? - FirebirdV6.com/CamaroV6.com Message Board
  • What is up with my RPM gauge?
    :eek:
    This has been a problem since I got the car. Start the car up and the needle goes all the way to the right. What needs to be done to fix this problem?
    Re: What is up with my RPM gauge?
    if when you start your car, it goes all the way over then back and settles into a normal reading, thats normal. it is doing a gage sweep which is self diagnosis. If it is staying there, most likely need to replace your cluster.
    2000 3.8 A4 Pewter Camaro
      the entire cluster? or can i just replace the RPM gauge?
      oh and how the hell do you take off the plastic around the cluster. The headlights switch is in the way and i cant get it totally off.
