Fan switch - FirebirdV6.com/CamaroV6.com Message Board
Fan switch
  • Fan switch
    Well i did a search on manual fan switches today , and found a "how to do" thing by one of the people from this site , thanks for it , helped a ton and wasnt to hard to do at all , well my question is just a simple one , on high speed is it normal for only one fan to go?On low both come on.
    Re: Fan switch
    no one?
      Re: Fan switch
      It is louder it is just one fan though , i dont see how i can have the wires switched , its only 2 wires , either way they both go to an ON connection of the switch
        Re: Fan switch
        my write up.
        high is one fan
        low is one fan
        It's normal.. if you listen, when the fan is on high it should be alot louder than the low speed.
        Glad the how-to helped.
        *Matt
          Re: Fan switch
          Originally posted by StrtRacer98
          my write up.
          high is one fan
          low is one fan
          On my 97, low speed was both fans, and high speed was both fans.
            Re: Fan switch
            It was only 2 wires right? my low speed is both fans , but high is just the one ....Mines a 96 , would that make any difference?
              Re: Fan switch
              mine was 2 wires, and a ground wire. Tapped into like H and J on the harness
              http://www.bowtiev6.com/
                Re: Fan switch
                Yea i have those same wires hooked up , maybe a fuse? what would be a reason that fan isnt working.....but yet is is....
                  Re: Fan switch
                  Put your AC on, this brings both fan on low speed. Now, with the ac still on, put your fan switch in the high postion. Now both your funs will run high speed.
                    Re: Fan switch
                    Well i gave it a try...and it worked! thx for that bobby , was starting to get a little annoying . and if thats what i have to do to get em to both come on then so be it .
