Getting Hot - FirebirdV6.com/CamaroV6.com Message Board
Getting Hot
  • Getting Hot
    Hello
    I own a 1997 White Firebird 3.8 V6.
    When I first bought the car it had a water leak. After trackign it down it was the elbow that is underneath the plenum. I have replaced that and also replaced the water pump and water transfer unit. Still I will be sitting there in traffic and it will shoot to 225 degrees. I put a 180 in it. Any ideas?
    Its got 98000 miles on it
    Re: Getting Hot
    When engine is cold do the following:
    1) Check engine coolant level in both the radiator (by removing the cap) and the reservoir. Top off as required and re-install the rad cap. Make sure the rad cap is installed properly (directions are on the cap)
    Start engine and when the engine is at operating temp do the following:
    1) Open the cooling system bleeder screw and look for a steady stream of coolant from the bleeder. If steam and air comes out, keep the screw open until you have an uniterupted stream of coolant. Then close the valve.
    2) Check the coolant level in the reservoir. Make sure it is at the proper level.
    Top off as required.
    3) Make sure your cooling fans are operating.
      Re: Getting Hot
      in addition to ^^^^
      the car should get up there normaly. You should also be able to see the temp go back down when the thermostat opens up.
      when you replaced all thosse parts, did you burp the system good?
      2013 Ram 1500 Big Horn
      94 comero 3.4
        Re: Getting Hot
        That has been quite a while ago. I have changed the oil since then and also filled it back up. I even had it flushed afterwards. Its really weird. It will work sometimes and lately its getting hotter more often. Also I remember my oil pressure at a steady pace when I first bought it but now its starting to get lower and lower. It sometime drops down to the first notch after the red line. Not all the way down but i guess I would say 1/4 of the way.
          Re: Getting Hot
          is the oiil pressure w/in the specs listed here?:
          http://forum.camarov6.com/forumdisplay.php?f=16
          94 comero 3.4
            Re: Getting Hot
            that link didn't lead to any thing. it lead to another forum
              Re: Getting Hot
              Originally posted by kala
              TEAM BLACK!!!
              parting her out
                Re: Getting Hot
                Hey Im trying here. ;) I am reading the forums and there is a lot of good stuff listed here. I have tried that seafoam in the past and OMFG.. The lady who had my car before me ran cheap gass.
                  Re: Getting Hot
                  crap, my bad :slap: ....... too many windows were going on
                  http://engine.firebirdv6.com/
                  there ya go
                  94 comero 3.4
                    Re: Getting Hot
                    Your cooling system could be clogged. I had a 95 Lumina that kept overheating like that, and then the next thing you know, I have coolant in my oil. It may need a professional flush done on your cooling system. I don't know about the oil pressure thing though, unless your heads have already warped from the heat (heaven forbid), but I don't remember if that causes problems with oil pressure.
                    Check that other thread: "Is this a blown head gasket!!??"
                      Re: Getting Hot
                      so? theres nothing wrong with cheap gas, actually its really good
                      are you trying to say that the seafoam cleaned your fuel system?
                        Re: Getting Hot
                        I wasn't laughing at you but the fact the wrong link was posted. You're right though, this site is awesome!!
                        TEAM BLACK!!!
                        parting her out
                          Re: Getting Hot
                          After leaving work yesterday I checked the oil pressure.. Its around 55 to 50.
                            Re: Getting Hot
                            So now your saying your oil pressure is OK?
                            I'm trying to get a sight on what your saying here. So you have a temp problem and an oil problem.
                            How frequenly does your engine run too hot, and does your oil pressure problem occurr at that time, or is that an independent thing?
                              Re: Getting Hot
                              Well.. Now I think I have a water leak somewhere. I checked the engine yesterday and the water level was freaking low. Last time I checked it was a week ago and it was fine. But I don't smell coolent. I wonder if its leaking where the block burns it off.
                              I guess I really had a question on the oil pressure. It says on that website that it should be at 60 psi. Well it hovers around 50 to 55 and somes drops down til 45 or so and then comes right back up. Depending on the RPM's. I don't think it should be that low. or am I wrong?
