OK my engien is STILL overheating, and sometimes its been redlining, i have to stop and shut it off! And i can hear tht fan super loud while the car is running, and ill stop the car the fan will run for about 5 mor min. i put in some more anti frieeze thought tht mighta been the problem, and it helped it for a couple days but its doing the same thing agan. i looked in my engine now and saw this, and i wonder if it looks like a blown gasket?
yep.. exactly check your oil.. coolant leaks into the oil if it's a head gasket leak. Hell you could've spun a bearing.. Check your coolant for leaks too. The only way to really tell is to bring it to a mechanic or to have a Block Check kit
~The Guru\'s Guru~<br />1999 Camaro,K&N,!MAF<br />!airsilencer,3.08s,<br />NGK-TR6\'s,Taylor Blue 8mm wires,FRAM,A4,Catco Cat, Magnaflow 3 inch catback,transgo shift kit<br />Waiting: RK sport headers, custom y pipe electric cutout<br /><a href=\"http://www.cardomain.com/id/divinejc\" target=\"_blank\">www.cardomain.com/id/divinejc</a>
Those are clear pictures, but I can’t tell for sure - isn’t that wet area under your water pump? Could be your water pump has gone out. They usually leak from the bottom whenever it’s time to replace one, and your car will over heat. Also, whenever you add coolant, make sure that it is mixed with water in the right proportions. I don’t think that it is advisable to add just coolant, or just water, it needs to be mixed - usually 50-50. Look to see if you have wetness under your water pump though, and take off your oil cap to see if there is moisture condensation under it. Then check your oil and see if there is some whitish looking stuff on the dip stick. The moisture condensation under the oil cap is a good (or bad) sign that the head gasket is blown, as well as the whitish looking stuff on the dip stick, which is oil and coolant mixed together.
never heard of one of those
The best thing to use is either:
Compression tester (cheap) OR
Cylinder Leak Down tester ($40 at harbor freight, but have to have an air compressor)
If there is air in the system the engine will (no ifs ands or buts) overheat.
If you find air when you open the bleeder you have to ask why air is there. Look for:
- low coolant level? because of head gasket leaks, external leakage
- improper coolant mixture? (water turns to steam and vapor locks)
If you don't find air, then you have to look for stuff like:
- Poor coolant flow (Thermostat not opening, plugged/clogged radiator, damaged/slipping water pump impeller, etc..)
- Poor airflow over radiator (debris blocking radiator, air deflector missing, cooling fans not operating.
here is another way to check for leaks!
you can go to Auto zone and ask to rent a coolant system pressure tester
it ia easy to use and very effective then when you are finished with it you can take it back and they will give you your money back.
Pressurize the system and you will see where it is leaking from
