Does Shell V-Power gas actually work? Does it actually clean your internals over time? Is it worth the extra $.30-$.40 a gallon?
Does Shell V-Power Actually Work?
Re: Does Shell V-Power Actually Work?
my guess is no. The fuel additiives in a bottle are known for not working, so I doubt this cleaner gas won't do jack either
If your engine, or injectors need cleaning, you take it or them apart and clean them. There so no magic bottle your dump into your tank that cleans anything as well as cleaning it by hand. I had ran 2 cans of seafoam, and EVERY other cleaner the auto parts sells, and my injectors were still a mess. Chevron with the techron, and shell v power, is supposed to be very good at KEEPING an engine clean. Notice i said keeping, and restoring. Ive posted this pic before, but will post again, my injectors, after running several cleaners, the handcleaning with carb cleaner, q tips, and opening and closing the injector with 12 volts.<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.
like 4 bolts that hold the injectors on
but you might have to take off other stuff to get to them like:
MAP sensor
and ICM bracket
Once you take off the injectors you MIGHT have to replace the o-rings
Depending on your year model it might be near impossible to open the injectors and clean them (its impossible on mine)2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
Bobbyz72 has a 1997 so I'm pretty sure you can dissassemble the injectors then!
go for it!
only bad thing i can think of is the o-rings breaking
dont forget to depressurize the fuel!
Should get better gas mileage with clean injectors2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
yea when you remove your injectors replace the orings even if they dont break. They are really cheap, like a couple bux for them all. Just a safety measure so they don't leak when you are done
by Andy HHey everyone! I've been trying to remove my transmission for two days now! I need to replace the clutch. Only thing I've got left holding the transmission...4 weeks ago
