I am leaking coolant from the back of the motor. Any suggestions?
Coolant Leak
Re: Coolant Leak
look where at
could be a few things. your intake gasket, head gaskets, casting plugs, etc.
Re: Coolant Leak
could also be rear main but I highly doubt it
casting plugs = freeze plugs = block core plugs?2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
Re: Coolant Leak
its just a metal, round plug in the back of your heads probably hidden by a layer of dirt or in the back of your block also hidden by dirt
Re: Coolant Leak
I replaced 2 of my block freeze plugs... they're easy to do
I would rather replace the ones on the bottom of the block, yes they are on the BOTTOM
I would hate to have to take off the heads, just to replace a freeze plug2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
Re: Coolant Leak
Originally posted by slow6I replaced 2 of my block freeze plugs... they're easy to do
I would hate to have to take off the heads, just to replace a freeze plugOriginally posted by kalaI'll have buttsecks with Richard Simmons!
TEAM BLACK!!!
parting her out
Re: Coolant Leak
I used metal ones... they were silver color
Havent came out since, or leaked
I did not pull the motor, just got underneath the car2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
Re: Coolant Leak
why use rubber? is that an aftermarket piece? I would assume the rubber wouldnt hold up either since your coolant system runs around 15psi
Re: Coolant Leak
18psi max here2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
Re: Coolant Leak
Mine was the intake gasket. Not only coolant but oil leak. $700 at the dealer.Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
by ssms5411So my truck is finally getting some work done, after 17 years, Oil pressure sensor went out and it’s located under the lower intake manifold. Have to...4 weeks ago
