automatic transmission fluid level? - FirebirdV6.com/CamaroV6.com Message Board
  • automatic transmission fluid level?
    i've searched around a good bit and found that we need about 5 quarts to fill the trans fluid,but is this when you remove the filter and what's in the pan?
    or is this all the fluid including what you don't get out?
    thanks
    Re: automatic transmission fluid level?
    um
    there will probably be fluid still all up inside the radiator and the cooler lines
    but my Manual says 8.8 oz of Dex 3!
    if its completely empty
    I'd rather be overful than too low
    but both is bad, its just too low is worse
      5 quarts for pan removal. 11 for overhaul
      2000 3.8 A4 Pewter Camaro
        thanks alot guys :banana:
          18 in my car :( :(
          www.turbov6camaro.com
          1997 3800 Series II Camaro
