so recienly my 2000 camaro has been hard starting...its not when you let it sit for long times its when you let it sit for just for like 10 minutes after u turn it off...i replaced the battery and put new plugs in there....my mechanic said it might be some seal in my fuel line that is shot...so it drips and causes somewhat of a flood but ya i dont understand it.. If anyone can help that would be greatly appreciated otherwise im taking her to the shop
Starting
Re: Starting
With the right tool to remove the snap ring, about 10 mins.<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.
Re: Starting
When i did mine on my 97, i had to buy snap ring tool with the 90 degree bend on the end. Your going to have to use a mirror to see what your doing. Basicly you remove the snap ring, pull out the regulator, push in new regulator, reinstall new snap ring, and reconnect vacuum line.<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.
Re: Starting
Yeah, i have big hands too and it was pretty tight. You know you could just remove the whole fuel rail, make it much easyer, and clean your injectors while your at it.<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.
