I have a 3.4L V6 firebird and i was wondering why everytime i start the car in the morning blue smoke comes out the exhaust its all stock... Just the other day it through a code that the "cat" was bad is that whats causing it?!?!? Or is it something else?
Blue smoke!!!!!
Re: Blue smoke!!!!!
it must be oil
so leaky oil control piston ring (the bottom ones)
or leaky valve2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
Re: Blue smoke!!!!!
In some instances, having a little smoke only on start up can be normal operation.
Most likely not though. The two things slow6 is right on what it could be
Re: Blue smoke!!!!!
a puff of blue smoke right at start up and not really noticable at any other time usually indicated leaking valve guide seals. if its not real bad, id leave it alone and check your oil level more frequently.Phill<br /><br />95 camaro... need money for turbo project... <br />94 S10 Blazer - winter beater - infinity system to be installed soon<br /><br />\"The man who says it cant be done should not interrupt the man doing it...\"
Re: Blue smoke!!!!!
Well Its not that bad but heres another thing and it barely happened too whenever i press on the throttle slightly i here this little ticking noise by the cylinder head drivers side but when i go WOT it seems to dissapear maybe because of the exhaust, huh?!?! anyways i already took the heads off just to check it out....I noticed that the rocker arms where lose on pistons number 6 & 4... i took some pics with my "chocolate" if i only knew how to post them up....Last edited by fbody; 10-10-2006, 12:19 AM.
Re: Blue smoke!!!!!
That ticking noise could be noisy injector or valve train noise.Now Playing: \'99 Pewter Firebird, stock, bone stock, and nothing but stock, so help me God!<br />Comming attractions: K&N Filter, Lid Mod, Intake Bellows Smooth Pipe Mod.<br />I dream about: Forced Induction (TC or SC) or NOX (or both!)
Re: Blue smoke!!!!!
this makes sense... burning oil.. especially something that seems like the valvetrain is causing the oil consumption.. prolly has some wear on the engine.. that light ticking noise sounds very much like a lifter... they are hydraulic and after a while, the internal seals start to leak and they do not hold internal oil pressure.
you fix this usually by replacing the bad lifter... not cheap, so usualy most people just deal with the ticking noise...Phill<br /><br />95 camaro... need money for turbo project... <br />94 S10 Blazer - winter beater - infinity system to be installed soon<br /><br />\"The man who says it cant be done should not interrupt the man doing it...\"
Re: Blue smoke!!!!!
Originally posted by camaroman1181this makes sense... burning oil.. especially something that seems like the valvetrain is causing the oil consumption.. prolly has some wear on the engine.. that light ticking noise sounds very much like a lifter... they are hydraulic and after a while, the internal seals start to leak and they do not hold internal oil pressure.
how much are we talking about?
Re: Blue smoke!!!!!
maybe try some ATF in your engine oil.. it has detergents that might clean it free from sticking
(if that is the problem)
which doesnt explain the blue smoke2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
Re: Blue smoke!!!!!
itll run a few hundred bucks, if ya do it yourself. you have to take the upper and lower intake manifolds off, the vavle covers, take off the rocker, remove pushrods, then remove the lifters and put it all back together again.. its gonna take you some time to do it right... personally, id say ya just put up with the noise..Phill<br /><br />95 camaro... need money for turbo project... <br />94 S10 Blazer - winter beater - infinity system to be installed soon<br /><br />\"The man who says it cant be done should not interrupt the man doing it...\"
Hey guys. For starters I’ve always been a big car guy, I love all types of cars and can appreciate all types of engineering. I’ve always been a Chevy...3 days ago
by ssms5411Getting a massage saying invalid interface, haven’t used it since last year probably November. First time in 23 years I had a problem. Going to get...5 days ago
need help finding a balancer and a replacement balancer bolt. im at a lost after confusing myself researching.1 week ago
