Blue smoke!!!!! - FirebirdV6.com/CamaroV6.com Message Board
Blue smoke!!!!!
  • Blue smoke!!!!!
    I have a 3.4L V6 firebird and i was wondering why everytime i start the car in the morning blue smoke comes out the exhaust its all stock... Just the other day it through a code that the "cat" was bad is that whats causing it?!?!? Or is it something else?
    Re: Blue smoke!!!!!
    it must be oil
    so leaky oil control piston ring (the bottom ones)
    or leaky valve
      Re: Blue smoke!!!!!
      In some instances, having a little smoke only on start up can be normal operation.
      Most likely not though. The two things slow6 is right on what it could be
      2000 3.8 A4 Pewter Camaro
        Re: Blue smoke!!!!!
        a puff of blue smoke right at start up and not really noticable at any other time usually indicated leaking valve guide seals. if its not real bad, id leave it alone and check your oil level more frequently.
          Re: Blue smoke!!!!!
          I would not worry about it too much. Monitor the oil level, if you are not losing oil quickly then I would just leave it alone.
            Re: Blue smoke!!!!!
            Well Its not that bad but heres another thing and it barely happened too whenever i press on the throttle slightly i here this little ticking noise by the cylinder head drivers side but when i go WOT it seems to dissapear maybe because of the exhaust, huh?!?! anyways i already took the heads off just to check it out....I noticed that the rocker arms where lose on pistons number 6 & 4... i took some pics with my "chocolate" if i only knew how to post them up....
              Re: Blue smoke!!!!!
              That ticking noise could be noisy injector or valve train noise.
                Re: Blue smoke!!!!!
                So maybe one of my injectors is bad??!?!?!?
                  Re: Blue smoke!!!!!
                  this makes sense... burning oil.. especially something that seems like the valvetrain is causing the oil consumption.. prolly has some wear on the engine.. that light ticking noise sounds very much like a lifter... they are hydraulic and after a while, the internal seals start to leak and they do not hold internal oil pressure.
                  you fix this usually by replacing the bad lifter... not cheap, so usualy most people just deal with the ticking noise...
                    Re: Blue smoke!!!!!
                    how much are we talking about?
                      Re: Blue smoke!!!!!
                      maybe try some ATF in your engine oil.. it has detergents that might clean it free from sticking
                      (if that is the problem)
                      which doesnt explain the blue smoke
                        Re: Blue smoke!!!!!
                        itll run a few hundred bucks, if ya do it yourself. you have to take the upper and lower intake manifolds off, the vavle covers, take off the rocker, remove pushrods, then remove the lifters and put it all back together again.. its gonna take you some time to do it right... personally, id say ya just put up with the noise..
                        • 187shark
                          by 187shark
