ignition coil going bad,, - FirebirdV6.com/CamaroV6.com Message Board
  • ignition coil going bad,,
    this is the 2nd coilpack tat is going on me. the #4 coil post is all discolored and looking rough as hell.. this same thing happened when i had the accel coilpacks...it's only the #4 post. what could be causing this
    Discolored and rough is bad? Mine keep turning the dielectric grease stuff black and they look pretty rough too. I took it all apart and soaked the ends in a water/baking soda mix as well as cleaned it with electric parts cleaner, seemed to help the kr at lower rpms for a while. Didn't help the top end though so I figured that it wasn't the problem.
    [ February 27, 2003: Message edited by: Ttop34 ]</p>
    1997 Nassau Blue Vette<br />1989 Jeep Cherokee 4x4 (lifted with 31\" tires)<br />2000 V6 Camaro, loud, cammed 210rwhp *SOLD*
      I had a pack go bad because the @%% that had the car before me was messing with it and did not get the bolt tight thus it vibrated and wore down and I was not getting a good ground. Just a thought.
      Remember that sometimes, silence is the best answer.<br />Warren White<br />1996 PoloGreen Coup <a href=\"http://vampyr.settanni.net/\" target=\"_blank\">http://vampyr.settanni.net/</a> <br />\"Jealousy\"<br /> CTFBA member of the month Sept 03
