please - FirebirdV6.com/CamaroV6.com Message Board
please
  • please
    i just cant figure this out... Im about to take down the gas tank and checking the gas pump its self.... As far as that valve i already checked that .... Nothin is coming out.... PLease I need some help... I dont want to do extra stuff.... if you this eny relays or enything might be burnt?
    huh?
    2000 NBM M6 Camaro Z28<br />323/335
      #2. I dunno... :rolleyes:
      Thanks, <br />JAM<p>02 Firebird GT
        umm.. you can check fuses..
        or just have someone sit on the ground behind the car and turn the key to the on position.. and let em listen to see if they hear the pump kick on..
        not really any relays to check as I don't think the pump uses enough electricty to justify a relay though I'm not 100% sure on that one..
        -Brad
        2000 V-Star Custom 1100
        :rock:
          Test the fuel pressure to the fuel rail. Hook up a fuel pressure tester to the valve on the rail. It'll have a black cap on it. Also with a test light, test to make sure you are getting power to the pump. If you need wiring diagrams, wire colors, or advice, let me know. I am a Tech for a Pontiac dealership and can e-mail you some info.
          • 187shark
            by 187shark
