Ok I am going to NAPA tomorrow, and I was just wondering what are some suggestions on the fluids i should put in my new engine im going to be putting in?
Oil
Power Steering
Coolant? (whats the mixture again?)
Other things i should get
TIA
'96 Trans Am M6:) Cam, lifters, 1.6rr, lt4 springs, 4 bolt mains, long tubes, TDs, short throw...etc
'99 Firebird SOLD 1/4 mile 15.4 @ 86
'66 Ford SOLD
Coolant should be a 50/50 mix. (Are you planning to use green or red?)
For the engine, I would suggest 5w30 motor oil.
I don't think the power steering fluid matters, use any.
Thats what I was asking about whats better red or green?
And my engine takes 10w30, I wanted to know about favorite brands.
'66 Ford SOLD
If you make a switch, just make sure you flush the other out really well. I like green.
I would use like the prestone dexcool and Mobil 1.
I personally use GM fluids cause the way i see it, my car cost me way to much to be cheap with....Except i use mobil 1 because well, gm doesn;t have an oil...really
