Fluids - FirebirdV6.com/CamaroV6.com Message Board
Fluids
  • Fluids
    Ok I am going to NAPA tomorrow, and I was just wondering what are some suggestions on the fluids i should put in my new engine im going to be putting in?
    Oil
    Power Steering
    Coolant? (whats the mixture again?)
    Other things i should get
    TIA
    '96 Trans Am M6:) Cam, lifters, 1.6rr, lt4 springs, 4 bolt mains, long tubes, TDs, short throw...etc
    '99 Firebird SOLD 1/4 mile 15.4 @ 86
    '66 Ford SOLD
    Re: Fluids
    Coolant should be a 50/50 mix. (Are you planning to use green or red?)
    For the engine, I would suggest 5w30 motor oil.
    I don't think the power steering fluid matters, use any.
      Re: Fluids
      Thats what I was asking about whats better red or green?
      And my engine takes 10w30, I wanted to know about favorite brands.
      '66 Ford SOLD
        Re: Fluids
        This has been discussed lately. Not sure if you'll get what yopu want out of these threads but here they are.
        coolant: http://forum.camarov6.com/showthread...hlight=coolant
        oil: http://forum.camarov6.com/newreply.p...ote=1&p=619052
        Originally posted by kala
        I'll have buttsecks with Richard Simmons!
        TEAM BLACK!!!
        parting her out
          Re: Fluids
          If you make a switch, just make sure you flush the other out really well. I like green.
            Re: Fluids
            I would use like the prestone dexcool and Mobil 1.
            I personally use GM fluids cause the way i see it, my car cost me way to much to be cheap with....Except i use mobil 1 because well, gm doesn;t have an oil...really
            2000 3.8 A4 Pewter Camaro
            • Andy H
              Transmission removal help!!
              by Andy H
            • 2.8 Bird
              Abs inop
              by 2.8 Bird
            • fishin
              by fishin
