Slight Hesitation and Ticking... - FirebirdV6.com/CamaroV6.com Message Board
  • Slight Hesitation and Ticking...
    When I press the gas on my 94 3.4, a brief hesitation occurs before the engine revs up. I'm not exactly sure what this means, but I've also noticed a rather loud ticking coming from the engine. I've read that the ticking can be the injectors; if so, maybe one or more is going out? Any suggestions? Thanks.
    Re: Slight Hesitation and Ticking...
    have you noticed your pedal difficult to gently press sometimes and that you have to push it harder than normal to get it to move? if so, your throttle body plate might have carbon built up causing it to stick for a sec.
    2000 3.8 A4 Pewter Camaro
