ok guys iwas gonna replace my coilpacks. well i wen to order my plugs and wires and they said msd coil packs were 50 somehting a piece..is this right, someone said they were only a little bit more than stock!! also i got ngk iridium plugs and msd wires, is that a good setup?
msd coil packs
yeah that is the right price for msd coils, the ac delco coils are like 40 dollars, but a lot of people buy the cheap 20 dollar coils from autozone. i've had all three and couldnt really tell a difference between them, except now i have the dis 4 and can tell a big difference with that. i run the 8.5mm msd wires and ngk plugs not the iridium ones though. sounds like a good ignition set up to me.95 3.4 m5- comp 206/212, 1.6 roller rockers, pacesetter headers, magnaflow cat, dynomax 18\" bullet muffler, ss muffler and tips, msd 8.5 wires, 32mm sway, umi sfc,
The setup your going to use chet mo is good, you don't really need the msd-4 unless your gong to be dong heavy modding and tunning. Plus the fact you have a 3.8 it isn't really neceasry, i would spend the money for the msd4 and get a tuner instead [img]smile.gif[/img]
3.4 they help alot.1999 Pontiac Trans Am M6 Far from stock.....
