I've got ~$150 to spend on my car. I've already have a cat-back exhaust and cold air intake, and was hoping to find something else to use it on. I was thinking I might be able to find a good used LSD and 3.42's, but is there anything else I should get? Should I do more engine bolt on stuff (if there is any), or should I go with drivetrain stuff now? I was hoping more engine wise, but anything is good, what would you guys recommend? I'm already talking to someone on here about a driveshaft, but I may go with something else.
Abit to spend
Re: Abit to spend
Originally posted by CamaroRSZ28SSComputer Tuning chips, 160* stat, camshaft, new pulley set, Throttle Body Coolant Bypass................have u done n e of those?~97 3.8L V6 Camaro~
A few things
Only Member of Team Hooker?!?
Re: Abit to spend
dont waste your time and money on chips, stats, or bypasses. all that does is make your car run TOO cold.
for $150, there isnt a hell of a lot you can do, usnfortunately. you have knocked out the cheap mods and now it gets tough. I would get some NGK spark plugs, maybe some taylor wires or something, then honestly save the rest for future mods.
Re: Abit to spend
for 150, I would upgrade to the aluminum driveshaft. Don't mess with the steel, go right to an aluminum one. You will notice a difference with this upgrade, at least I did and most people I talk to have.
Re: Abit to spend
Originally posted by 97rs4lifefor 150, I would upgrade to the aluminum driveshaft. Don't mess with the steel, go right to an aluminum one. You will notice a difference with this upgrade, at least I did and most people I talk to have.
Re: Abit to spend
Originally posted by UDLOSE98correction, I like his idea, I have a Alumin DS for sale! : )~97 3.8L V6 Camaro~
A few things
Re: Abit to spend
you could get a cam, but your budget is gonna be short for it. cam install run around like 500+ once you get all the valvetrain upgrades and all.
gears and posi upgrade is tough to find for 150 or less. Used rear ends go for 300 bucks.
Re: Abit to spend
Originally posted by UDLOSE98if you are refering to the came in the for sale section, you are gonna need some work done to your valve train to handle it.
EDIT: Nvm, did some readin on it, and I don't want it afterall. So, I may be interested in your DS. I would really like to find a LSD and gears though. How much of a difference would I see form the DS? I know it won't be much, but just an estimate.
EDIT 2: Did some more searching (I'm a good boy :P ) and foudn that there's about an average of .2 coming off of 1/4 times with a aluminum shaft. So, all I can say is I think you should hold that one for me man. I should hopefully have the money by either tomorrow or Wednesday (depends on if I have time to get to the bank tomorrow).Last edited by RadRacer; 10-16-2006, 08:34 PM.~97 3.8L V6 Camaro~
A few things
by Andy HHey everyone! I've been trying to remove my transmission for two days now! I need to replace the clutch. Only thing I've got left holding the transmission...2 weeks ago
