Oil Filter - FirebirdV6.com/CamaroV6.com Message Board
Oil Filter
  • Oil Filter
    What oil filter do you guys use?
    I was using the K&N's but they are just to expensive.
    Re: Oil Filter
    3.8s use a ac delco, ph-47
      Re: Oil Filter
      Ac delcos form autozone... I alsot use XX52 (forgot the exact letters, so I put XX)
      its oversized and car takes more oil. More filter, more room to filter, also helps use up that last .5, so its almost a complete 5 quart oil change instead of 4.5q
      the stock size is xx47 though.
        Re: Oil Filter
        k and n HP1001 all the way!!! the only way to go i heard mobil had some good filters but i haven't ever used anything but k and n
        2001 Camaro 3.8 A4
        1991 3000GT VR4
        2001 Mitsubishi Eclipse GS
          Re: Oil Filter
          little pricy man I have used K&N since i got the car and i don't have the money right now.
            Re: Oil Filter
            AC Delco PH-52. They work great.
            1995 Patriot Red T-Topped Z28 A4<br /><br />Mystery rebuild in progress.<br /><br />Soon to have 383 ways to beat KBreezy and Shane. :D
              Re: Oil Filter
              Theres no way in hell, that an extra inch longer filter will hold half a quart. I used the 47s and used the full 5 quarts. Maybe a little over full, but at 3000 miles of leaking, and engine oil burning, it would always be perfect on full. Also, the 52 filter is too long, you hit a hard bump, that babys taking damage, and you maybe walkin.
                Re: Oil Filter
                An oil filter is an oil filter, dont waste your money on kandn
                  Re: Oil Filter
                  I use the Fram filters with the "sure grip".
                    Re: Oil Filter
                    our cars take PF-47
                    2000 3.8 A4 Pewter Camaro
                      Re: Oil Filter
                      im about 99.9 percent sure the cheap walmart super tech brand ones are the same as the bosche ones. made by champion labs. i am not positive but this issue has been covered before on other forums.
                        Re: Oil Filter
                        I didn't say it takes a full half a quart, I said it uses more, and is closer to the .5 quart.
                        and I can gurantee that it won't hit, if you hit a hard bump. Believe me, my car has been through a million situations and never damaged it...
                          Re: Oil Filter
                          i think hes talking about the 3.4? no?
                          fuk fram
                            Re: Oil Filter
                            Originally posted by slow6
                            fuk fram
                            I have used only 4 frams with the sure grip, in each case the shur grip got oil on it and started pealing off making a mess on my hands.
                              Re: Oil Filter
                              It is all a matter of opinion. I have used Fram filters for the last 15 years and I have never lost an engine. So people hate them, I like them.
