i know it would be illegal, but how would i make a switch to shut off the lisence plate lights at night?
lisence plate light
Re: lisence plate light
Originally posted by jeffkiernani know it would be illegal, but how would i make a switch to shut off the lisence plate lights at night?
So if someone is driving at night and they rearend you and hurt you and some of your occupants, then they turn the license plate light off so they can make a quick getaway and you cannot identify the vehicle or owner...then what??? Or...same question, but they hit a pedestriain which turns out to be a loved-one.sigpic
tkae off you back bumper, cut the negative wire in half. extend the two lines into the cabin of the car through the hatch and under the carpet to the desired location near you dash. hook the two lines onto a switch. when switched on, this will complete the circut and allow the negative charge to ground out making the light bulb light up. when off, the charge doesnt go anywhere and cannot pull electricity through the bulb
good luck, and it wont do anything but give a cop reason to stop you. also, with your relective tag it wont matter much. but have fun.
Originally posted by jeffkiernanthat is exactly why im doing it, so i can go around hitting people and hitting cars and take off.
Originally posted by Choppershockey man where did you get your clear corner lenses and what brand are they?sigpic
the license plate light isnt that bright. and if any light at all hits it it reflects. mine bulb was out for a while til a cop say me at a party while i was pulling up and used it as an excuse to stop me and check out the party. the only thing the light will do is let a cop know that you have a license plate, from a distance, and maybe whta state your from.
Originally posted by Chopperswere you pleased with the fronts then?
hockeyman
I know it's basically a theory, but since the front corners were such a pita to remove, I bought the Long Life Replacement Bulbs. They were a bit more than the regular bulbs, but once you take the corners out and reinstall, you don't ever want to do them again! Some say that the long life bulbs are a waste of money, but I didn't want to take the chance.sigpic
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...3 days ago
by ssms5411Not much going on, replaced my Kenwood double din stereo with a Pioneer double din, the Kenwood had problems. Then replaced my power inverter for my reverse...6 days ago
by DoodlerHi, everyone. We bought a 97 base model convertible Camaro and someone broke the motor ... Lights were blinking on the dash and that someone ignored the...4 weeks ago
