How do these mods sound? - FirebirdV6.com/CamaroV6.com Message Board
  • How do these mods sound?
    Ok, as of now I only have a clamp-on K & N filter, TB spacer, and a Polished Stainless Magnaflow exhaust (2.5" outlet). I'm planning on going with PaceSetter ceramic coated headers, high-flow cat, Magnaflow cat-back dual exhaust, and possibly an aftermarket cam.... Should I expect decent hp gains from this setup or should I go with something else?
    On the cam, which manufacturer should I go with?
    1995 Pontiac Firebird 3.4L
    I'm looking for the best products for my money. I was also told that an aftermarket thermostat will increase my power a bit. Is this true? Any info on mods will be greatly appreciated....
    Re: How do these mods sound?
    This setup will work well but you don't need true dual exhaust. The headers and cat will give decent gains. CompCams makes a few cams that will work with the stock tune of the 3.4.
    A 180 thermo will help a little bit.
      Yea you dont need a true dual exhaust. Its just not necessary for our cars. As for the cam, I have the NA cam from abbott racing, comp cams makes it. But abbott has everything you need. I suggest checking it out.
        agreed, and to add, dual will actually cause you to LOSE hp. The thermo is good for 3-4 hp tops, so dont think too far into it.
          But thermos are like $15 so there worth it...
          '66 Ford SOLD
            if you arent running the right tune for that respective thermo it may be no good at all.
              you might want to consider ditching the 2 peice driveshaft and get an aluminum one
              - youll feel more throttle response and better mpg, less rotating mass, they are also stronger, check forsale sections on here and www.ls1tech.com they cost between 100 and 130 shipped
              A new rear end is a good investment too, with an LSD and disc brakes
              -Im no expert one this seeing as i have not done this but the LSD will give you better traction off the line, the higher gear ratio (3.43 or 3.73) while slightly decreasing your mpg will give you a noticable difference in acceleration they cost around 250 (i think)
              - and who wouldn't want disk brakes?
              Those are just some mods to look into, use the search feature if they sound like things you wanna consider
              K&N air filter, Whisper air lid, magnaflow LT1 cat back, and magnaflow high flow cat, pacesetter headers, silverstars<br /><br />more to come soon<br />but for now im out of money
                Good point; however, 180 with a stock tune of the 3.4 is fine.
                  nah a stock theremostat is good for a stock 3.4, unless you have the comp reprogramed to advance the timing and turn the fans on earlyer a colder t-stat is accually hurting you
                  you want to run as hot as possible (with out pinging)
                  underdrive pullies are good on a 3.4 if you don't already have 'em
                    The fan only matters when you are not moving. I agree the 160 hurts but not the 180.
                    Good point. A cheap couple of HP for the 3.4
                      if you want to add all those parts anyway, you should get a tune regardless. In all honesty, the tune i got was more noticeable than any part i put on the car. Granted the tune was designed for the all the bolt-ons. I run a 160* t-stat with no complaints.
                      Black 1996 3.8 Firebird T5, SLP CAI, Pacesetter Ceramic Headers,160* t-stat, PCMforLess Tune, Flowmaster American Thunder catback, Car Sounds Cat, custom s-pipe, MSD coils and wires, NGK plugs, 3.42 posi rear, B&M Ripper, 245/50 BFG-G-force's
                        I've got a 180* stat... i like it but i fear going back into open loop on the interstate with the heat on... the temp gauge is below 180 going 75 and there really isnt much for heat out of the vents. and the fans still dont kick on til like 220 or something higher.
                        anyone know at what temp the OBD-1 cars go into closed loop operation, and if it is possible to go back into open loop from a 180 stat?
                          You have a 3.8 Tunes for the 3.4 are much harder to come by and are more expensive. One get a lot of HP out of the 3.4 w/ the stock tune.
