OK. I've had my car for about 5 months now. Everything runs good and all, but I'm not sure when the last little check-up was done. I changed the oil about 3K ago, and am about to do it again, so I figured maybe I should go ahead and do everything else. By everything else, I mean seafoam the whole car, and change plugs and wires. What do you guys think? Wires look stock to me, and I've kinda been wanting to go upto some 8.2mm ones. Is there anything else I should do? Car has about 76k on it, and it's a 97 3.8 Camaro. So, should I go ahead and do all this, or is it just a waste of time and money at this point? If I did plugs and wires, I was gonna go with Taylor or MSD wires, and then NGK plugs.
General Maintenance
Re: General Maintenance
Originally posted by silversixxWow thats great milage for a 97! But yea, i would do a tranny flush, seafoam, wires, plugs, and an oilchange. Also if you havent already put a k&n air filter on it nows the time. :)~97 3.8L V6 Camaro~
A few things
Only Member of Team Hooker?!?
If you are gonan do everythign Id flush the radiator, chnge the diff fluid, chagne the power steering, fuel filter, tranny fluid and filter and the brake fluid so you know its all up to date. Better off doing that so you knwo its done.01\'Y87 Firebird:Gt1 cam,Vig.3000 stall
www.vaperz.com
Originally posted by Firehawk N WvIf you are gonan do everythign Id flush the radiator, chnge the diff fluid, chagne the power steering, fuel filter, tranny fluid and filter and the brake fluid so you know its all up to date. Better off doing that so you knwo its done.~97 3.8L V6 Camaro~
A few things
