Used Differential questions - FirebirdV6.com/CamaroV6.com Message Board
  • Used Differential questions
    1. How do you know if a differential bearing is bad?
    I ordered one off ebay and want to know if the
    bearings are good. Apparently, if I buy 2 bearings from autozone for 10.99 each, it'll cost me $250 to have them pressed on [img]graemlins/omg.gif[/img] .
    2. Do you need to add grease or anything to the bearings?
    3. Is a dial indicator really needed to do an lsd swap? I have 3.08 gears and the lsd is 3.08.
    4.This lsd manual says to use hypoid non synthetic gear oil (80w-90) and additive. Does anyone do this??
    http://www.auburngear.com/aftermarket/common/literature/Diff_Install_Instructions.pdf#search='differential %20gear%20installation'
    [ July 31, 2005, 11:10 PM: Message edited by: joecool ]
    #1- don't know, but for the cost of new bearings I wouldn't take a chance on old ones. I think it would be more like $250 for someone to prep and install everything [and even that seems a little high].
    #2- dunno; I doubt it. Isn't it immersed in the gear oil?
    #3- dunno; I'm paying someone else to do this
    #4- I've seen this recommendation on an Eaton posi also. If it's from the manufacturer's mouth, I would do what they say. The additive is probably the GM stuff you get from the dealer.
    \'00 f-bird 3.8 M5 coupe, pewter metallic<br />Torsen LSD, Pro 5.0 shifter, Spec stage 1 clutch, Y87 muffler, aftermarket stereo<br />-more fun than the Oldsmobile it replaced...
