I went to change my spark plugs and the boots will not come off of them ? do they screw off or just yank off?
Spark plug boot removal??WTF
Re: Spark plug boot removal??WTF
They just pull straight off. Be careful not to rip the boot though. Make sure you take off the heat shields first. Those are a PITA to get off too sometimes.
Here's a lil tip too, before you put them back on, go to an autoparts store and get some Dieletric Grease, coat the inside of the plug wire boot with the grease and it will be 1000000x easier to get them on and back off next time. :)sigpic
1997 Camaro RS A4
2006 Chevy Colorado
2003 Kawasaki Ninja ZX6-R
Twisting them to break them loose before you pull on them can help too.Drivetrain Moderator - "There are no stupid questions, only stupid people!"
2001 Pewter Firebird Y87, M5
Go Sabres!
go buy a spark plug terminal plier. (boot puller)
twist some and pull
by Andy HHey everyone! I've been trying to remove my transmission for two days now! I need to replace the clutch. Only thing I've got left holding the transmission...2 weeks ago
