Experts help in stumped!!!!!! - FirebirdV6.com/CamaroV6.com Message Board
  • Experts help in stumped!!!!!!
    ok so yesterday my car ran perfect and todayit seized upno warning nothing WTF? ......oil perfect level ,,no leaks....just had headgaskets changed. engine has 103000 miles on it but im stumped it gave no warning just bam run like **** then seized up:mad:
    Re: Experts help in stumped!!!!!!
    Im no expert by any means, but because the HG were just changed, can they be leaking antifreeze by any means? Might be one thing to check.
      yea, I'm also no expert, but sounds like a hydrolock to me
      Custom interior...
      TEAM NoVa
        will it start at all?
        Follow me!
        Or this
          ITwontstart andlocked up when i tryto startit allthe gauges jumped....!! my odometer resets too...but im taking on monday to the place where i got my heads done will update soon!
            I recommend that you remove the sparkplugs,..and then attempt to crank the engine over. See if coolant shoots out of a plughole or two. Is your radiator level low? Did this happen while driving or after a prolonged rest where a leaky headgasket could have filled a cylinder? Try out this test and it might verify the problem. Good luck!
