ok so yesterday my car ran perfect and todayit seized upno warning nothing WTF? ......oil perfect level ,,no leaks....just had headgaskets changed. engine has 103000 miles on it but im stumped it gave no warning just bam run like **** then seized up:mad:
Experts help in stumped!!!!!!
Re: Experts help in stumped!!!!!!
yea, I'm also no expert, but sounds like a hydrolock to meRebuilding the engine... Building a custom front end... T-top conversion... Custom rear hatch..
Custom interior...
TEAM NoVa
I recommend that you remove the sparkplugs,..and then attempt to crank the engine over. See if coolant shoots out of a plughole or two. Is your radiator level low? Did this happen while driving or after a prolonged rest where a leaky headgasket could have filled a cylinder? Try out this test and it might verify the problem. Good luck!
