Does any one know if the 94 Grand Pix 3.4L DOHC will go in to a 94 FireBird with a little truble or lot
trying to see if a 3.4DOHC will go in my 94 FBird
Re: trying to see if a 3.4DOHC will go in my 94 FBird
it'll fit.... but it will take ALOT of work
and the dohc weights as much as an LT1 (why I din't go thru with it)Wolf<br /><a href=\"http://www.cardomain.com/memberpage/249111/7\" target=\"_blank\">95 black t-top camaro</a>,3.4 5 speed,ud pullies,plugs/wires,de-shaft tb & gutted airbox, homemaid short throw shifter
it might work, but all the mounting points are wrong..
if you want do anything, get a set of 3400 Al heads off a fwd engine and swap those with the intake. theres more info on this in an advanced tech sticky.. much better flow, along with less weight, for what is more or less a bolt on swap (with minor fabrication).. tuning would help a lot too, but if you are going with FI, youll need tuning anyways..Phill<br /><br />95 camaro... need money for turbo project... <br />94 S10 Blazer - winter beater - infinity system to be installed soon<br /><br />\"The man who says it cant be done should not interrupt the man doing it...\"
Originally posted by camaroman1181it might work, but all the mounting points are wrong..
Originally posted by 97rs4lifehe will need more than just the 3400 heads and intake for that swap, you also need to swap the pistons and rods for that as well or the compression is going to ruin the engine
agreed... there are also things like injectors, different coolant temp sensors, etc... i was just mentioning the basic swap, since the rest of the info is in the sticky i referred to..Phill<br /><br />95 camaro... need money for turbo project... <br />94 S10 Blazer - winter beater - infinity system to be installed soon<br /><br />\"The man who says it cant be done should not interrupt the man doing it...\"
the 3.4L though a nice motor when it works, is quit possibly the most unreliable motor GM made in recent years, I would never want to ever swap that thing into anything...
