I am looking for a pcm from a 96 3.8 that has y87 3.42 option stock, i need everyone with this to respond, i need the service number off the pcm its on the white tag please help me out
Anyone with a 96-97 3.8 that had y87 3.42 stock please respond asap
Longtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,Tags: None
Ok, no offsense but you are posting MANY very basic questions.. you need to do a little more research before you flood up general tech...
secondly 96 and 97 pcm's are not the same.. 97 will work in 96 no problem but you can't reprogram a 96 with 97 code nor can you program a 97 with 96 code.
I should have another 97 3.42 pcm for sale soonKeith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
I didnt know that if i did a search that i would find peoples vin numbers and service numbers , is that pcm you have programmed did you ever tear it open or remove the chip, have you altered it in any way?Longtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,
i have several pcm's where I've torn down and removed the chip.
It's not a moving part.. there is no "wear and tear"
It's an electronics device.. it either works.. or it doesn't.. no maybes.Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
i have a 96 i need the service number not the vin number, the service number is on the white tag on the pcm, i was told that the 97 pcm will work in my 96 so when i get it programmed i guess i will have to tell the person that it is a 97 pcm right?Longtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,
I stopped driving...3 weeks ago -
Well, I finally am getting some time to get back into these cars. Today I installed a set of no name eBay stainless headers that I’ve had for probably...4 weeks ago
