2002 firebird v6, got home and the water temp gauge show the temp lower then 100. I was thinking that it was the thermostat I change it today no change, still the same problem,
also the cooling fan is on all the time as soon as you start the car, and ses light is on.
Is it safe to drive ??? and whot could be wrong with it help ????????
Maybe your stat is stuck open, it will make the car run very cool, because it will be letting all coolant flow. Take it out and inspect the spring and if its working. I am going to say its safe to drive as long as its not too cold out.
My 96 only starts at 160, yours starts at 100? If your saying that basically the guage is not heating up at all then it could be just the sensor is bad. Not sure how your guage cluster works but maybe it has a sepaerate fuse for this.
That's what I was thinking. There's most likely a fuse for the temp sensor/temp read-out that you may have blown. Check all your fuses and see if any's gone.
Working on getting my 99 Camaro back in action. Long story short, got parked in the garage about 5 years ago (kids, career stuff ect.) trying to get her...
I have a 15 year boy now (crazy how time flies from when I was a teenager on here!) and his first car will be the old Camaro.
I stopped driving...
