pleaese someone help please! : ( - FirebirdV6.com/CamaroV6.com Message Board
  • #16
    Re: pleaese someone help please! : (
    Originally posted by BLLDOGG
    Pull the plugs
    just curious, did you funnel it into the hose of the actual booster?
    yea i funneled it into the brake booster **** im screwed i tried to turn it over before and its a little better then nothing it cranked a few times i think the seafoam is evaporating out i guess idk but im gunna pull the plugs i have a warranty thank god on all internals i didnt know seafoam could hydrolock an engine thats ridiculous i didnt even funnel 1/3 of the can in? but to let everyone know its a 98 camaro if anyone has any info that would be great
    • #17
      doode you need to quit trying to turn that **** over if you did hydrolock that **** and you keep tryin to turn it over you can bend some **** like you um i dunno.... connecting rods..or valves.. or even brake your timing chain so stop pull the plugs crank it over and see if anything comes out of the hole other wise get that **** towed to a good shop and get it looked at if you dont know what your doing... oh and a tip for the future if you dont know ask and find out first or just dont do it cause that **** can get expensive you know
      • #18
        Pull the plugs, crank it a few times... let the seafoam dry/evaporate overnight... i'd say try it after that, but i'm no pro... I seafoamed yesterday and my only problem was after i choked the engine off, it shot the seafoam in the brake line back out and into my eyes. yea u definitely should wait a long time to start that puppy up.
        • #19
          I dont know if I would feel comfortable letting seafoam choke / killl my engine
          • #20
            u have to. if u pour it in with the engine off, it doesnt go anywhere, or it hydrolocks like the originator of this thread. if u pour it in slow and it doesnt kill it, it gets burnt up right away/before it can soak into and break up the carbon buildup.
            • #21
              a warrenty wont help you when you caused the problem. I hope for you they don't send out an adjuster and the tech doesnt say anything. doubtful thouhg on the adjuster thing
              2000 3.8 A4 Pewter Camaro
              • #22
                i let the car sit over night and i started it in the morning and it took a little bit and it was running fine idle smooth and all but then i shut it off and went to start it and it was just dead again and when i tried to turn it over it just clunked real loud again..so im going to get it towed to a shop tomorro morning hopefully the warranty will cover the engine internal that broke...i really just want to drive this car off a bridge its been nothing but a problem since i bought it..
                • #23
                  Im not sure something broke in the engine if it ran fine. are your describing the loud click of the starter?
                  • #24
                    sounds like you might just have a bad starter
                    • #25
                      don'tt tell the shop anything about the seafoam
                      ' it just started doing this crap yesterday for somereasson......."
                      2013 Ram 1500 Big Horn
                      94 comero 3.4
                      • #26
                        man that sucks i hope it all works out for you!
                        2001 Camaro 3.8 A4
                        1991 3000GT VR4
                        2001 Mitsubishi Eclipse GS
                        • #27
                          yeaa im not going to tell the shop...thanks alot guys hopefully i get the car fixed this week its on the flat bed rite now leaving :(
                          • #28
                            the shop called today they got the car running ...they said that the car idles and runs fine...the starter went thats what was causing the noise so im pretty happy
                            • #29
                              LMAO, funny how it went out at the scaryest possable time. Oh and by the way, if your upper end needs cleaning, take the **** appart and clean it. Ive tryed every cleaner they make experimenting to see if any worked, non of them did ****. People think seafoams works cause it causes temporty smoke. Well, i can pour diesel, wd40, break cleaner or transmission fluid down a vacuum line and make smoke too, diesel would probly clean the best anyways..lol. Trust me, your wasting your money buying that stuff.
                              • #30
                                haha i know man im going to get that **** apart as soon as i get it back.. is it easy to replace the starter because i dont think it can be that hard and im not paying a shop to do something i can do myself
                                • 187shark
                                  by 187shark
