Originally posted by BLLDOGG: </font><blockquote>quote:</font><hr />Originally posted by John_D.: The connector to the light sensor is a two wire connector. Put a jumper between the two wires to disable the auto headlights. Put a switch in your jumper wire, to control whether the auto feature is disabled or not...
this is the best answer so far, thanks :D </font>[/QUOTE]BTW you trying to stalk someone? [img]graemlins/naughty.gif[/img]
Originally posted by malice10985: I have wanted to get rid of that damn sensor for years now. I have just never gotten around to it.
I have a haynes manual with lots of wiring diagrams. Maybe it is in there somewhere. I will do some under-dash surgery on saturday and take pictures. We should make a mod review for this and settle it once and for all.
yep, i'll get to it saturday. we'll se what we can do :D
Originally posted by viper04af: </font><blockquote>quote:</font><hr />Originally posted by BLLDOGG: </font><blockquote>quote:</font><hr />Originally posted by John_D.: The connector to the light sensor is a two wire connector. Put a jumper between the two wires to disable the auto headlights. Put a switch in your jumper wire, to control whether the auto feature is disabled or not...
this is the best answer so far, thanks :D </font>[/QUOTE]BTW you trying to stalk someone? [img]graemlins/naughty.gif[/img] </font>[/QUOTE]lol, no. im very happy with my girl
I just looked in the haynes manual. It says it is a 2 wire connector, just like John D said.
The wire colors are:
-light green/black
-yellow/black
speedy-v6-camaro-
what does the sensor look like? I imagine it is a little round glass thing, like a cd player eye.
Do we have to remove the whole dash, or just a little piece of it?
1999 red camaro v6 M5: with a turbo<br />13.52@107.99<br />No, seriously: Who Farted? <br /><a href=\"http://www.cardomain.com/memberpage/600086\" target=\"_blank\">http://www.cardomain.com/memberpage/600086</a>
Just the top of the dash....its one big piece of plastic. Its just a photoelectric eye that connects the wires when it light out. You will see it easily in the top vent when you take it out. Just be careful not to break the dash.
the wire is a fat red one right behind the headlight switch...you should be able to see it if you take off the ac vent by the window on that side...snip that wire...and your headlights will work fine...but you wont have the auto headlights anymore
Originally posted by 1DangerousV6: the wire is a fat red one right behind the headlight switch...you should be able to see it if you take off the ac vent by the window on that side...snip that wire...and your headlights will work fine...but you wont have the auto headlights anymore
that sounds way easier. I will try that instead.
Originally posted by ABH: Put the hand brake up one click. I read somewhere that 1 click does not engage the rear brake.
This is true however I have read it can cause other items to turn off as well. Here is a site with instruction on how to disable them... does not look hard.
malice ...i found this out because my auto headlights actually stopped working...i looked behind the headlight switch to see if anything was wrong...that wire i was talking about came undone where the factory had crimped it..its probably the same color and all on your car but you might want to get a wiring diagram just in case
I took out my headlight switch, and there were 2 fat red wires. I went ahead and did it Hawgs way. It way easier than I thought. I thought the whole dash had to be removed, but the light sensor is easy to get to from the radio hole.
I would have taken like 10 minutes, but the Jehovahs witnesses came into my garage and started preaching to me!! They wasted a half hour, so it actually took 40 minutes. Next time I will pull into the garage and close the door. :mad:
Originally posted by BLLDOGG: </font><blockquote>quote:</font><hr />Originally posted by viper04af: </font><blockquote>quote:</font><hr />Originally posted by BLLDOGG: </font><blockquote>quote:</font><hr />Originally posted by John_D.: The connector to the light sensor is a two wire connector. Put a jumper between the two wires to disable the auto headlights. Put a switch in your jumper wire, to control whether the auto feature is disabled or not...
this is the best answer so far, thanks :D </font>[/QUOTE]BTW you trying to stalk someone? [img]graemlins/naughty.gif[/img] </font>[/QUOTE]lol, no. im very happy with my girl </font>[/QUOTE]OIC gotta sneak in late [img]graemlins/naughty.gif[/img] [img]graemlins/banana.gif[/img]
