Oil Pan - FirebirdV6.com/CamaroV6.com Message Board
Oil Pan
  • Oil Pan
    My oil pan is rusting out and i plan on getting a new one soon. How hard is it to replace? What do i have to do to put it in like what things do i have to take out as in transmission or whatever??
    Re: Oil Pan
    Do you have a haynes or chilton's manual? If not, buy one, read it,
    then ask questions.
    And no I'm pretty sure the tranny doesnt have to come out.
      Re: Oil Pan
      do a search man. It is difficult to do.
      2000 3.8 A4 Pewter Camaro
        Re: Oil Pan
        Try cleaning it and polishing it?
        just a thought.
        '95 3.8L A4 PGM. & '95 LT1 M6 PGM. :burn:
          Re: Oil Pan
          then ask questions.
          Where do i buy one?
            Re: Oil Pan
            autozone, Oreilly's, Pepboys, etc
              Re: Oil Pan
              Do they make em like special for Camaros or is it for like a variety of cars kind of book?
                Re: Oil Pan
                lol....its special for the car
                  Re: Oil Pan
                  just a thought.
                  Yea i was gonna do that im just interested in how to get it off mostly:)
                    Re: Oil Pan
                    just a thought.
                    your post was almost right, you just left out the part about repainting it... to protect it
                    There are rust cleaner kits
                    I would clean all the rust off and spray paint over it really good
                      Re: Oil Pan
                      Nah i meannn like getting the actual oil pan off
                        Re: Oil Pan
                        ya, i know you wanna change it out (hard to do)
                        but im saying you can just easily repair it real quick
                        but, its a critical component so if you insist on swapping it out, go for it
                          Re: Oil Pan
                          haha im not insisting on swapping it out i just wanna polish it in paint it but im most critical about how to get it off like what other components i have to take out to get that oil pan offff Thanx for the help
                            Re: Oil Pan
                            i wouldnt take it off just to paint it, unless there was a area you couldnt get to.
                            Youre gonna have to have an engine lift i believe. its alot of work, but i havent done it before
                              Re: Oil Pan
                              how did you manage to rust your oil pan out??? Oh and its lots of work, i had to remove my tranny also.
                              • Andy H
                                Transmission removal help!!
                                by Andy H
                              • 2.8 Bird
                                Abs inop
                                by 2.8 Bird
                              • fishin
                                by fishin
