seafoam questions - FirebirdV6.com/CamaroV6.com Message Board
seafoam questions
This topic is closed.
  • seafoam questions
    Hello.
    I just seafoam my gas tank, and my car feel a lot better now. My question is I just change my spark plugs. The plugs only have less then 50 miles on them. I spend a lot of money on these NGKs http://store.summitracing.com/partde...0&autoview=sku. Do I really need to change the plugs to sea foam the brake booster line? Is it really hard to take off the brake booster line? By the way my car is a 01 Camaro with 53,000 miles on it.
    Thanks.
    Re: seafoam questions
    no you dont have to change your plugs. it can be hard depending on where you live and how hard you drive the hose can get baked to the booster make sure the car is running when you use the decarb doit though did you read about the guy who hydolocked his motor LOL
      Yeah I read it about it LOL. He should of read this thread from LS1 tech http://ls1tech.com/forums/showthread.php?t=534376
        the brake boost line is pretty difficult to reach if your is the same as my 98, it is backed up againt the firewall. I have to basically remove the upper intake to access mine.
          mine is easy to get to :D
          2000 3.8 A4 Pewter Camaro
