hey does anyone make an alt.or a ps underdive pulley that will fit the 3800 engine?
3.8 underdrive pulleys
Re: 3.8 underdrive pulleys
here u go
wp
http://www.zzperformance.com/grand_p...ts1.php?id=196
alt
http://www.zzperformance.com/grand_p...ts1.php?id=2062000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainers
Originally posted by bigralph 2Would these to type of pulleys work on a 01 camaro? What is the difference between a 14% underdrive, and a 10% overdrive alternator pulley? Also how hard is it to remove stock alternetor pulley and install the new one?
basically, underdrive pullies don't take as much power from the engine, but they don't give as much power to the accessory either. Overdrive pullies take more power from the engine, but they give more power to the accessory.
You typically see overdrive pullies on superchargers, since it increases the supercharger's output.\'98 Camaro - SOLD<br />Best E/T: 15.489 @ 86.48 MPH<br />60\': 2.131<br /><a href=\"http://members.cardomain.com/skorpion317\" target=\"_blank\">members.cardomain.com/skorpion317 </a><br />1998 Saturn SL2<br />Official <a href=\"http://www.njdisturbance.com\" target=\"_blank\">NJ Disturbance</a> bracket racer
From my understanding our cars are already underdriven. So buy getting after markter bullies there is no real benefit. I wouldnt waste the money on them Frank.01\'Y87 Firebird:Gt1 cam,Vig.3000 stall
AR stage 3 heads/intakes to be installed
www.cardomain.com/id/firehawknwv
www.vaperz.com
PEWTER MAFIA/ Kristen's "PEWTER MAFIA KING"
Originally posted by Firehawk N WvFrom my understanding our cars are already underdriven. So buy getting after markter bullies there is no real benefit. I wouldnt waste the money on them Frank.
3.8s are already 'under pullied'.
My brother put underdrive pullies on the 3.4. Install was pretty easy. An impact wrench helps a lot though, because the alternator bolt is ON thereBlack \'94 Trans Am A4- SLP CAI & Loudmouth<br />Red \'93 Firebird A4- Ram Air under the WS6 hood, !cat, exhaust.
