On my 1995 3.4, if the AC is off, it wont come on til the car is around 220+ degrees... that sucks. Whenever im cruising slow down the beach or town, i have to keep the AC on even if the ttops and windows are down to keep the car at a decent temp isntead of a 180 to 220+ cycle. I would like it to come on at like 200 or so... Thanks
How do i change what temp the radiator fan comes on?
Ric Johnson<br />----------------<br />1995 Pro AM III #12<br />3.4 A4<br />KN FIPK intake with ram air mod<br />Flowmaster exhaust<br />RKSport IAT sensor <br />ASP Underdrive pullys<br />TB Bypass<br />PF52 larger oil filter<br />3.42 non posi rear end<br />DeCarbon Trans Am shocks<br />Eibach pro series springs<br />B&M Shift Plus+ (best $40 ive ever spent)<br />Custom made billet alum front end inserts<br />Interior trim painted to match the car<br />Awia CD player with factory bose sound system<br />Viper alarm system<br /><a href=\"http://www.proam.webhop.org/\" target=\"_blank\">http://www.proam.webhop.org/</a>Tags: None
just put in a manual fan switch<a href=\"http://www.geocities.com/atg284\" target=\"_blank\">http://www.geocities.com/atg284</a> <br /><br />1996 Black RS<br />3.8L --V6 -- A4<br />y87 performance package--flowmaster--SLP CAI--fan switch--3.42 gears--nos 5175 <br /><a href=\"http://camaroz28.cardomain.com/id/theforgottenfbod\" target=\"_blank\">http://camaroz28.cardomain.com/id/theforgottenfbod</a>
Any walkthru's online? Not too familer with the 3.4 wiringRic Johnson<br />----------------<br />1995 Pro AM III #12<br />3.4 A4<br />KN FIPK intake with ram air mod<br />Flowmaster exhaust<br />RKSport IAT sensor <br />ASP Underdrive pullys<br />TB Bypass<br />PF52 larger oil filter<br />3.42 non posi rear end<br />DeCarbon Trans Am shocks<br />Eibach pro series springs<br />B&M Shift Plus+ (best $40 ive ever spent)<br />Custom made billet alum front end inserts<br />Interior trim painted to match the car<br />Awia CD player with factory bose sound system<br />Viper alarm system<br /><a href=\"http://www.proam.webhop.org/\" target=\"_blank\">http://www.proam.webhop.org/</a>
not sure with the 3.4 but im sure there is some one on here with it. do you have a fan relay in your fuse box in your enging?<a href=\"http://www.geocities.com/atg284\" target=\"_blank\">http://www.geocities.com/atg284</a> <br /><br />1996 Black RS<br />3.8L --V6 -- A4<br />y87 performance package--flowmaster--SLP CAI--fan switch--3.42 gears--nos 5175 <br /><a href=\"http://camaroz28.cardomain.com/id/theforgottenfbod\" target=\"_blank\">http://camaroz28.cardomain.com/id/theforgottenfbod</a>
No i just turn the AC on when it gets too hot. The fan doesnt normally switch on til the car is almost boiling over...Ric Johnson<br />----------------<br />1995 Pro AM III #12<br />3.4 A4<br />KN FIPK intake with ram air mod<br />Flowmaster exhaust<br />RKSport IAT sensor <br />ASP Underdrive pullys<br />TB Bypass<br />PF52 larger oil filter<br />3.42 non posi rear end<br />DeCarbon Trans Am shocks<br />Eibach pro series springs<br />B&M Shift Plus+ (best $40 ive ever spent)<br />Custom made billet alum front end inserts<br />Interior trim painted to match the car<br />Awia CD player with factory bose sound system<br />Viper alarm system<br /><a href=\"http://www.proam.webhop.org/\" target=\"_blank\">http://www.proam.webhop.org/</a>
dont turn on the AC! it just raises the temp, get a lower trermostat or a fa switch.<a href=\"http://www.geocities.com/atg284\" target=\"_blank\">http://www.geocities.com/atg284</a> <br /><br />1996 Black RS<br />3.8L --V6 -- A4<br />y87 performance package--flowmaster--SLP CAI--fan switch--3.42 gears--nos 5175 <br /><a href=\"http://camaroz28.cardomain.com/id/theforgottenfbod\" target=\"_blank\">http://camaroz28.cardomain.com/id/theforgottenfbod</a>
Is there any way to modify the car the way it is to turn the fan on at a lower temp? Or do i have to ghetto rig in a switch?Ric Johnson<br />----------------<br />1995 Pro AM III #12<br />3.4 A4<br />KN FIPK intake with ram air mod<br />Flowmaster exhaust<br />RKSport IAT sensor <br />ASP Underdrive pullys<br />TB Bypass<br />PF52 larger oil filter<br />3.42 non posi rear end<br />DeCarbon Trans Am shocks<br />Eibach pro series springs<br />B&M Shift Plus+ (best $40 ive ever spent)<br />Custom made billet alum front end inserts<br />Interior trim painted to match the car<br />Awia CD player with factory bose sound system<br />Viper alarm system<br /><a href=\"http://www.proam.webhop.org/\" target=\"_blank\">http://www.proam.webhop.org/</a>
i think im the only one up but, ive never heard of anyone riging it. you should have a fan relay somewhere, you can tap a 12 volt source into it to make a fan switch.<a href=\"http://www.geocities.com/atg284\" target=\"_blank\">http://www.geocities.com/atg284</a> <br /><br />1996 Black RS<br />3.8L --V6 -- A4<br />y87 performance package--flowmaster--SLP CAI--fan switch--3.42 gears--nos 5175 <br /><a href=\"http://camaroz28.cardomain.com/id/theforgottenfbod\" target=\"_blank\">http://camaroz28.cardomain.com/id/theforgottenfbod</a>
I mean rigging by adding a switch. There should be no need to add a switch.. the factory setting is set somehow, there must be a way to change it...Ric Johnson<br />----------------<br />1995 Pro AM III #12<br />3.4 A4<br />KN FIPK intake with ram air mod<br />Flowmaster exhaust<br />RKSport IAT sensor <br />ASP Underdrive pullys<br />TB Bypass<br />PF52 larger oil filter<br />3.42 non posi rear end<br />DeCarbon Trans Am shocks<br />Eibach pro series springs<br />B&M Shift Plus+ (best $40 ive ever spent)<br />Custom made billet alum front end inserts<br />Interior trim painted to match the car<br />Awia CD player with factory bose sound system<br />Viper alarm system<br /><a href=\"http://www.proam.webhop.org/\" target=\"_blank\">http://www.proam.webhop.org/</a>
you could buy a pcm programer but im not sure if they make one for the 3.4L<a href=\"http://www.geocities.com/atg284\" target=\"_blank\">http://www.geocities.com/atg284</a> <br /><br />1996 Black RS<br />3.8L --V6 -- A4<br />y87 performance package--flowmaster--SLP CAI--fan switch--3.42 gears--nos 5175 <br /><a href=\"http://camaroz28.cardomain.com/id/theforgottenfbod\" target=\"_blank\">http://camaroz28.cardomain.com/id/theforgottenfbod</a>
Ill buy one tomorrow if they make one [img]smile.gif[/img]Ric Johnson<br />----------------<br />1995 Pro AM III #12<br />3.4 A4<br />KN FIPK intake with ram air mod<br />Flowmaster exhaust<br />RKSport IAT sensor <br />ASP Underdrive pullys<br />TB Bypass<br />PF52 larger oil filter<br />3.42 non posi rear end<br />DeCarbon Trans Am shocks<br />Eibach pro series springs<br />B&M Shift Plus+ (best $40 ive ever spent)<br />Custom made billet alum front end inserts<br />Interior trim painted to match the car<br />Awia CD player with factory bose sound system<br />Viper alarm system<br /><a href=\"http://www.proam.webhop.org/\" target=\"_blank\">http://www.proam.webhop.org/</a>
