I just finished replacing the intake plenum gasket on my 20002 camaro, but Im having trouble getting the injectors to go back in! does anyone have any advice?
Fuel injector problems! PLease help!
Re: Fuel injector problems! PLease help!
did they slide on the rail when you had it off? They should sit right back in
lightly grease the o rings, and bottom of injectors, then they will slip right in. i had the same problem.<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.
You could use gasoline, but it would be better (and safer) if you use vaseline (petroleum jelly). vaseline will not affect the rubber o-ring, and will not foul up the injector (if you use too much and it gets all over the place) cause it can readily be disolved by gas.Now Playing: \'99 Pewter Firebird, stock, bone stock, and nothing but stock, so help me God!<br />Comming attractions: K&N Filter, Lid Mod, Intake Bellows Smooth Pipe Mod.<br />I dream about: Forced Induction (TC or SC) or NOX (or both!)
what part of texas you in?<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.
by Need4CamaroThe panel under the HVAC controls where the button is supposed to be is completely missing when I bought the car so I dont know if this car had TCS or...3 weeks ago
by Need4CamaroI was wondering, are these cars DBC or DBW?
If swapping in an LS motor (lets ignore the rest of the complexity of the swap), what would be...3 weeks ago
