Fuel injector problems! PLease help! - FirebirdV6.com/CamaroV6.com Message Board
  • Fuel injector problems! PLease help!
    I just finished replacing the intake plenum gasket on my 20002 camaro, but Im having trouble getting the injectors to go back in! does anyone have any advice?
    Re: Fuel injector problems! PLease help!
    20002 camaro, pics?
    jk
    ahmmmm the rail should slide right over the intake, cant imagine what the hold up would be
      I have the injectors over the intake, I just cant get them to plug back into the holes on the engine where they are supposed to go back in.
      I'll try to post some pics sometime soon I just havent had time.
        did they slide on the rail when you had it off? They should sit right back in
        http://www.bowtiev6.com/
          I'm just going to try to replace the o-rings and see if that will work. Thanks for the help.
            lightly grease the o rings, and bottom of injectors, then they will slip right in. i had the same problem.
              Thanks for the advice. I may also try to let them soak in gasoline for awhile.
                You could use gasoline, but it would be better (and safer) if you use vaseline (petroleum jelly). vaseline will not affect the rubber o-ring, and will not foul up the injector (if you use too much and it gets all over the place) cause it can readily be disolved by gas.
                  what part of texas you in?
                    I'm from ther Sherman area about an hour north of Dallas.
