I just finished replacing the intake plenum gasket on my 20002 camaro, but Im having trouble getting the injectors to go back in! does anyone have any advice?
Fuel injector problems! PLease help!
Re: Fuel injector problems! PLease help!
did they slide on the rail when you had it off? They should sit right back in
lightly grease the o rings, and bottom of injectors, then they will slip right in. i had the same problem.<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.
You could use gasoline, but it would be better (and safer) if you use vaseline (petroleum jelly). vaseline will not affect the rubber o-ring, and will not foul up the injector (if you use too much and it gets all over the place) cause it can readily be disolved by gas.Now Playing: \'99 Pewter Firebird, stock, bone stock, and nothing but stock, so help me God!<br />Comming attractions: K&N Filter, Lid Mod, Intake Bellows Smooth Pipe Mod.<br />I dream about: Forced Induction (TC or SC) or NOX (or both!)
what part of texas you in?<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.
Hey guys. For starters I’ve always been a big car guy, I love all types of cars and can appreciate all types of engineering. I’ve always been a Chevy...3 days ago
by ssms5411Getting a massage saying invalid interface, haven’t used it since last year probably November. First time in 23 years I had a problem. Going to get...5 days ago
