my brake light is on and wont go off and i basicaly have to push the brake pedel almost all the way just to stop whats going on. and anotherthing my alarm isnt working the ligh that usualy blinks the u trgger the a;arm is on solid and and wont go off unless u start the car
HELP
This topic is closed.
The light turns on if:
-parking brake is on
-low brake fluid
-catastrophic failure of the brake system
Brake fluid doesn't just get "low" on its own. You have a leak somewhere. It needs to be fixed or your brakes may fail completely without warning at the worst possible time. Don't mess around with this one by putting it off.\'00 f-bird 3.8 M5 coupe, pewter metallic<br />Torsen LSD, Pro 5.0 shifter, Spec stage 1 clutch, Y87 muffler, aftermarket stereo<br />-more fun than the Oldsmobile it replaced...
Brake fluid will burn, it has a flash point!Black \'96 RS Camaro, 3.8 V6 Series II, M5, Stock 200 HP, 204K miles! Stock \'91 Firebird 3.1 V6 automatic w/ overdrive. 266,400 miles on it. \'83 Pontiac Trans Am,305 LG4, Cowl Induction,Borg Warner 5 Speed,T-Tops,Gale Banks Exhaust System:$800 obo
Brake fluid will boil first. Could he have enough water [=bad] in the brake system that the level goes down that much when he got it hot?
Either way, any smart person would get under the car, check all the lines for leaks, and bleed the system totally. The performance of the brake fluid is compromised once you start boiling it.\'00 f-bird 3.8 M5 coupe, pewter metallic<br />Torsen LSD, Pro 5.0 shifter, Spec stage 1 clutch, Y87 muffler, aftermarket stereo<br />-more fun than the Oldsmobile it replaced...
