VERY MAD! I need help, coolant leaking!! - FirebirdV6.com/CamaroV6.com Message Board
  • VERY MAD! I need help, coolant leaking!!
    I just put in a new belt tensioner. All good to go. I connect both heater hoses to it, put water in the radiator, once it starts to get filled water comes out of BOTH hoses, not the actual hose but that stupid connector thing??
    What can i do, ANYONE??
    Re: VERY MAD! I need help, coolant leaking!!
    Size motor? Year? Pics? If its a 3.4, are you talking about the quick disconnect fitting in the front of the intake?
      wow my bad,
      97 Firebird 3.8 112K
      I am talking about the heater hoses that come through the firewall from the heater core, right to the belt tensioner.
        Do you have both of locked on tight? Try taking them off and putting them back on, maybe something did not grap right.
          I also had this problem. I had accidently lost an o-ring/gasket that is right at the end of one of the hoses. Fortunatley the o ring was laying on my driveway.
            check the old part, maybe o rings are left inside it.
              O rings, where do they sit? on the metal piece of the connector?
                If im right they should be on the end of the hose. Just flip them up and take a look. They could have fell off if the hoses blew off.
                  yup thats PROBOBLY the problem, im so pissed. I cut one of thsoe connectors off the heater hose so i can rig up another hose to cover the whole thing..........and now i see where the o-ring goes!! Soo madd now
                  haha thanks guys, looks like ill be spending $150 at the stealership tomorrow.
                    Not sure if your on a time constraint or not but I replaced this hose assembly and ordered from gmpartsdirect about 2 years ago and I think it was under a 100 bucks.
                    Originally posted by kala
                    TEAM BLACK!!!
                    parting her out
