The window or door im not sure but it jiggles what i drives and it bugs the crap out of me how can i fix this?
Back window/door
Re: Back window/door
well the only way to fix it is to figure out what exactly is rattling. It could be anything back there. Maybe have someone ride back there and try to figure it out as you drive.
we can't really help ya out on that problem till you pinpoint where it is coming from or what it is
Here are 3 different ideas that you can try one at a time.
1. Check the spare tire and jack, make sure they are stowed properly.
2. The rear hatch has two little bumpers located in the rear corners. Try to back them out a little. That will tighten of the tension on the latch, it might help.
3. Put the back seat down, see if the noise goes away. If it does then it is the seat that is rattling.
Originally posted by nascar24jdHere are 3 different ideas that you can try one at a time.
One of two of those little bumper things i guess the trunk was slammed so hard one of them went thru the fiber so we had to put a piece of metal and put it thru their ill take a picture cuz its hard to explain it might be the problem
Part of owning a fbody is driving around trying to figure out where rattles are coming from. I usually drive for a little while then pull over and mess with something and see if it stopped the rattle.
nascar24jd had some good suggestions. The spare tire is a pretty common rattle.
by DoodlerHi, everyone. We bought a 97 base model convertible Camaro and someone broke the motor ... Lights were blinking on the dash and that someone ignored the...18 minutes ago
by ssms5411Still trying to find oil leak on my Camaro, it’s a tough one. I think it is the oil pressure sender myself. Leaking when raving and going into boost....3 days ago
