Engine is Cutting PLEAZE HELP - FirebirdV6.com/CamaroV6.com Message Board
  • Engine is Cutting PLEAZE HELP
    :rant: my engine is spitting and spurtering whenever i gun it. i have already tried to put new plugs, wires, and an oil change. the only thing that i can think of it being is the wires because it started right after i put them on they are 8mm accel. so if have any suggestions please let me know.
    Re: Engine is Cutting PLEAZE HELP
    It could possibly be a coil as well. Did the SES light come on? Is it turning over as soon as you turn the key or is it taking a second or two? I would first check the plug wires and if it is still doing the same thing, check your coils. Good luck and I hope you get it fixed.
    Sincerely,
    Justin
      if it just started doing it after the plugs I would check to make sure you didn't cross any or put them on the wrong coil pack or anything. Sounds like a possible wire problem.
      http://www.bowtiev6.com/
        yea, i replaced my wires and plugs when mine was cutting out, and that did the trick. to me it is worth it to buy the more expensive wires, i should have, but didnt.
          thanks for the tip i will diff. try that
