3.4L Vacuum Fitting Part Number Please - FirebirdV6.com/CamaroV6.com Message Board
  • 3.4L Vacuum Fitting Part Number Please
    I have looked throught GM Parts Direct and I cannot find the part number that I need. I have a 1993 3.4L and I need the vacuum "T" fitting that sits right in the middle (toward the front) of the intake manifold. Mine has cracked. One end of this fitting runs to the PCV Valve, and the other end runs to the Purge Solenoid.
    Can anyone get me the part munber so that I can order it from GMPartsDirect.com.
    Thanks in advance.
    Re: 3.4L Vacuum Fitting Part Number Please
    I don't remember the part number, but if I do remember correctly you have to buy the entire vaccum line system.
    Mine crapped out on my 3.4L and all the vacuum lines is all they woudl sell me.
    And no superglueing will not work either(I tired that)
      Originally posted by DAS BOOT
      I don't remember the part number, but if I do remember correctly you have to buy the entire vaccum line system. Mine crapped out on my 3.4L and all the vacuum lines is all they woudl sell me. And no superglueing will not work either(I tired that)
      Mine actually popped off the other night when I went to start it in front of a convenience store. Between the loud exhaust and the high revs from the vacuum leak I scared the heck out of a bunch of people. I shut it down, opened the hood and saw the problem right away. I have a small hose clamp hold it secure right now because the big piece has a crack in it and will not fit snugly.
      Does the dealer stock it? Can I buy it online?
      Thanks...
        I don't know... I was at my g/f's parents in tampa, and I stopped by their local dealer, to get the part, but its also a storage warehouse for the FLorida, so it was in stock their.
        dig up the 93-02 f-body parts manual and look it up at GM parts direct. Or just see if you can find the part from them their.
        Maybe check autozone, they surprise me in some of the replacement parts they carry.
          Pcv Vly Hose Harness
          10217828
            Thanks for your help.
              10217828
              Thank you very much, I will order it.
