rpm problenms - FirebirdV6.com/CamaroV6.com Message Board
rpm problenms
  • rpm problenms
    Ok so my rmp have been going really high when im drive on the street. It will go all the way up to 4 0r 5 rpm be for it shifts down. but it does this for a little bite of drive once been driving it works fine. Then on the freeway the rmp jump around from 3 to 2 then back to 3. But again it only does it for a little while what could be causing this it a 95 3.4 auto
    Re: rpm problenms
    Check your transmission fluid.
    Is it just getting to those high of rpm's by pressing the gas and it not shifting until late, or is it revving that high on it's own?
    If it is revving that high on it's own, check your vacuum hoses for any leaks or cracks.
    Is your SES light coming on or anything like that?
      Re: rpm problenms
      when i press the gas its shifting late
        Re: rpm problenms
        Waht color is your tranny fluid?
          Re: rpm problenms
          a really dark red
            Re: rpm problenms
            How many miles since your last change of the tranny? How many total miles on the car? Highway or city? You are checking its level while it is idle right?
              Re: rpm problenms
              whlie i just got it a month ago the last owner said he had a the fuilds changed about a week b4 it went up for sell. It has 130k . yes im checking it in idle
                Re: rpm problenms
                Here is a snap of what mine looked like, This fluid has around 400 miles on it. Its actually a little lighter then what the picture made it look like. Your not talking brown here right? I had minor transmission problems @ 126K on my old A4 between 2nd and 3rd. Think the person you bought it from wot around town or grannied it?
                http://www.avp2mods.com/tran.jpg
                  Re: rpm problenms
                  What are u saying here. mines is much darker then that.
                    Re: rpm problenms
                    Ohh if yours is much darker then that then yea its WAY time for a total change and new filter. I would say the previous owner did not include trans fluid change in his "fluids list". Does it have a smell to it by any chance? I would get that done pronto dude.
                    What I was asking is if the guy drove conservativly or recklessly. Which is somewhat moot if you have sick fluid color, its bad and needs to go.
                      Re: rpm problenms
                      ok i will get that done do u think that is what the problem is??? how many miles should u change it? he was an older man and the only owner of it so i dont think he drove it hard but i dont no
                        Re: rpm problenms
                        It is said to do it every 30,000 miles or 24 months, whichever comes first. I would advise you to do it every 15-20,000 miles or every 10-12 months, whichever comes first since there are so many miles on it.
                          Re: rpm problenms
                          Tranny fluid & filter should be changed out every 30K in my opinion. 15K if your in really bad urban settings, towing cattle trailers (lol) ect, but 30K is a good guideline. Check you trans fluid color every time you check oil. You can go and have someone do it for you, but ask them for the old filter. It should be pretty rank. Or you could get some ramps (I like safe) and do it yourself in a hour tops. Whatever you do I would take a bottle of the used trans fluid and the filter to the guy and explain what fraud in the inducement is. Again does it smell burnt? If so then you may well be smelling some cooked internals. Could it be on the way out? Well changing the fluid will help you assess that. If that does not help then consider it a possibility. Wahtever you do dont go to aamco!
                            Re: rpm problenms
                            ok thanks for the info i will change it and go from there. no it dont smell burt how much would a new tranny cost or to get it rebuilt
                              Re: rpm problenms
                              I just bought a 14K salvage engine & tranny outta a 2001 camero. Cost was 1100 shipped. Check car-parts.com for a better idea in your location. Labor for the install of the trans will vary, shop every mechanic and get everything in writting. Also have them factor in parts replacement with that labor. I compromised a bit on the ppl that installed. 1200 mechanics bill, (Yea, first and last time I am paying for that) Would have learned how myself, but have a really shaky trans on my beater truck and fbirds DD.
                              I would not have someone rebuild it, these trans just can be had for cheap with a few days looking around.
                                6 days ago
