MSD coil packs - FirebirdV6.com/CamaroV6.com Message Board
MSD coil packs
  • MSD coil packs
    Are the MSD coils worth the money on a 99 V6? Will they improve power, or make the engine run better.
    Thanks for your time!
    Re: MSD coil packs
    do some searching it all depends is what people are seeing on the dyno, but in theory a hotter spark should make more power and make your car run smother.
      Re: MSD coil packs
      yes to everything.
        Re: MSD coil packs
        there are mixed feelings to these. Most stick with the stockers
        http://www.bowtiev6.com/
          Re: MSD coil packs
          i cant say i noticed cause i put MSD wires,coilpacks, msd ignition, and E3 spark plugs on my 99 maro. i did notice a difference with all that stuff though. lol
          come get some
          http://www.canyoumaketheturn.com/
            Re: MSD coil packs
            My car seemed to run smoother with the MSD coil packs.
            01\'Y87 Firebird:Gt1 cam,Vig.3000 stall
            www.vaperz.com
              Re: MSD coil packs
              what about the summit packs that look similar?
                Re: MSD coil packs
                Well, Summit is a name you can trust as it hasn't seized to amaze people for many years, and no doubt for many years to come. Though, for coil packs I would go with the MSD's unless you find a review where someone compares them to the MSD's or makes the statement from proven facts that they are somewhat better than the MSD's.
                I guess really you should just do a good bit of research and find as many reviews/testimonials about the product, but base your decision off of cold hard facts, not just opinions. Some people will base their opinion off of what they want to believe, not always is it accurate to what the outcome really is.
                  Re: MSD coil packs
                  man, they are the same thing both of them is made in mexico only one red the other black,,,for me the only change it made was withe the msd ignition
                    Re: MSD coil packs
                    i want the Jeg coil packs are they good?
                      Re: MSD coil packs
                      unlessu change wires and plugs, are coil packs worth it??
                        Re: MSD coil packs
                        They are, but without changing the plugs and wires along with them, you won't even notice a difference. That's my opinion, however.
                        But, if you are thinking about getting them, you might as well go ahead and do it, because they are better and you will have to change your plugs and wires eventually.
