just bought two brand new ones... do i have to take it to a dealer for them to program...??? does anyone know how to do it... since dealer is going to charge me 40 bucks.....
programming keyless remote
Do not take it to the dealer....here you go...
Turn ignition switch to OFF position.
Remove RADIO fuse 17 from fuse block.
Cycle ignition switch from OFF to RUN three times within five seconds until the door locks and the hatch release cycle, indicating the Body Control Module is in the Programming Mode.
Press and hold BOTH LOCK and UNLOCK buttons on remote control door lock transmitter for 16 seconds.
Door locks will cycle once, confirming the transmitter code is programmed. The door locks must cycle completely to unlock before proceeding.
Any transmitter code that was previously programmed has been erased.
Body Control Module is now programmed to remote control door lock transmitter.
When programming the Body Control Module to match remote control door lock transmitters, the first transmitter code matched will be stored in memory unless a second remote control door lock transmitter is matched at the same time. If programming the Body Control Module to match a second transmitter, repeat step 4. This must be done before the RADIO fuse 17 is reinstalled.
Ignition switch to OFF.
Reinstall RADIO fuse 17 to fuse block.<a href=\"http://www.onid.orst.edu/~waltejam/\" target=\"_blank\">98 Bright Red Camaro</a><br />Too many mods to list....check my website
will that programming work with any car??? my dad has a 95 olds aurora that he got at an auction and i know they came with keyless... would i program it the same way.?02 camaro \"silver bullet\" slp CAI, flowmaster american thunder catback, custom 35 anniversary brake light, custom bowtie side markers, custom painted bowtie tailight covers,12 disc cd changer, 18\" replica z06 wheels..
i highly doubt that it would work on any other vehicle but the Camaro or Firebird. i could be wrong but who knows. Gm can be weird some days. but those steps sound right. my battery went out on mine and i had to redo the remotes.i don't know why but i did. oh well [img]graemlins/burnout.gif[/img]2000 Grand Prix GTP- Bronzemist Metallic: K&N Fenderwell Intake,3.4\" Thrasher Pulley, v1.0 DHP PCM, 3\" Mandrel Bent DP,Ubend Delete,Dynomax SuperTurbos, 180* Thermostat.<br />Soon to come: ZZP SSIntercooler or N20 or both:)
nope it didn't work... he just doesn't want to pay a dealer 40 bucks for 30 seconds of work...02 camaro \"silver bullet\" slp CAI, flowmaster american thunder catback, custom 35 anniversary brake light, custom bowtie side markers, custom painted bowtie tailight covers,12 disc cd changer, 18\" replica z06 wheels..
